i am following this steps to install rabbitmq on ubuntu 16
echo "deb http://www.rabbitmq.com/debian/ testing main"  | sudo tee  /etc/apt/sources.list.d/rabbitmq.list > /dev/null
wget https://www.rabbitmq.com/rabbitmq-signing-key-public.asc
sudo apt-key add rabbitmq-signing-key-public.asc
sudo apt-get update
sudo apt-get install rabbitmq-server -y
sudo service rabbitmq-server start
sudo rabbitmq-plugins enable rabbitmq_management
sudo service rabbitmq-server restart
after executing >> sudo apt-get install rabbitmq-server -y i am getting following error
Reading package lists... Done
Building dependency tree
 rabbitmq-server : Depends: erlang-base (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                            erlang-base-hipe (>= 1:21.3) but it is not going to be installed or
                            esl-erlang (>= 1:21.3) but it is not installable
                   Depends: erlang-crypto (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-eldap (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-inets (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-mnesia (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-os-mon (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-parsetools (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-public-key (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-runtime-tools (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-ssl (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-syntax-tools (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-tools (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
                   Depends: erlang-xmerl (>= 1:21.3) but 1:18.3-dfsg-1ubuntu3.1 is to be installed or
rahul.m
  • 125
The first step to solve your issue is to revert the effects of your commands.
Let's start with your first command.
This is creating a the file /etc/apt/sources.list.d/rabbitmq.list. So you want to delete this file. To delete the file run the following command.
sudo rm /etc/apt/sources.list.d/rabbitmq.list
Your next command is downloading a file.
You can just delete the file if you know where it was downloaded. It should be downloaded in the directory from which your command was executed. If you just opened a terminal, it is very likely that it is in your home directory.
The next command is adding a gpg key with apt-key. So you have to remove the gpg key. See the answers to this How can I remove gpg key that I added using apt-key add -?.
Now that you have removed the gpg key. You should run sudo apt update
You are now ready to install RabbitMQ following the official instructions. The official instructions are not the best organized. However I have tried to distill the commands for ubuntu 16.04.
First step is to install Erlang. Run the following commands. Here I am just copying commands from the link.
curl -fsSL https://github.com/rabbitmq/signing-keys/releases/download/2.0/rabbitmq-release-signing-key.asc | sudo apt-key add -
sudo apt-get install apt-transport-https
echo "deb http://dl.bintray.com/rabbitmq-erlang/debian xenial erlang-22.x" >  | sudo tee  /etc/apt/sources.list.d/bintray.erlang.list > /dev/null
sudo apt-get update -y
sudo apt-get install -y erlang-base \
                    erlang-asn1 erlang-crypto erlang-eldap erlang-ftp erlang-inets \
                    erlang-mnesia erlang-os-mon erlang-parsetools erlang-public-key \
                    erlang-runtime-tools erlang-snmp erlang-ssl \
                    erlang-syntax-tools erlang-tftp erlang-tools erlang-xmerl
Now you should have Erlang installed. Now you can install RabbitMQ. You should run the following commands.
sudo apt-get install curl gnupg -y
echo "deb https://dl.bintray.com/rabbitmq/debian xenial main" | sudo tee /etc/apt/sources.list.d/bintray.rabbitmq.list
sudo apt-get install -y rabbitmq-server
You should have RabbitMQ installed now.
