I had a 750GB hard drive (/dev/sda1) that I replaced with a 1TB SSD (/dev/sdb1). I wanted to then erase the old HDD and use it as a backup drive. However, it seems that the boot partition is still on the old drive, and grub finds no boot on the new drive. This creates a few problems:
The default OS at grub is then Ubuntu 16.04 on the HDD, instead of Ubuntu 18.04 on the new drive. If I am not there to pick which OS, it goes to the old one, which is not really functional.
I cannot erase the old HDD until I have a proper boot on the new SSD.
I recently installed HWE on Ubuntu 18.04, so that I can use the 5.0 kernel, however it doesn't seem to use or recognize that kernel. I suspect that this is also grub related, so it seems best to fix grub first.
What is the least painful way to do this? I am guessing that I need to boot in from a live CD, modify the partition on my SSD, and install a bootloader somehow. Can anyone point me to some instructions on how to do this without screwing up my OS or home directory?
This post looks similar, but scared me a bit: Remove second hard drive OS from grub
Details of my system:
~$ uname -a
Linux xxxxx 4.15.0-33-generic #36-Ubuntu SMP Wed Aug 15 16:00:05 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.3 LTS
Release: 18.04
Codename: bionic
Results of sudo parted -l :
Model: ATA WDC WD7500BPKT-0 (scsi)
Disk /dev/sda: 750GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 50.0GB 50.0GB primary ext4 boot
2 50.0GB 750GB 700GB extended
5 50.0GB 66.0GB 16.0GB logical linux-swap(v1)
6 66.0GB 750GB 684GB logical ext4
Model: ATA Samsung SSD 840 (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 1000MB 999MB fat32 boot, esp
2 1000MB 17.0GB 16.0GB linux-swap(v1)
3 17.0GB 67.0GB 50.0GB ext4
4 67.0GB 1000GB 933GB ext4
Error: /dev/sdc: unrecognised disk label
Model: Initio INIC-1610P (scsi)
Disk /dev/sdc: 4142MB
Partition Table: unknown
Disk Flags:
Model: Linux device-mapper (crypt) (dm)
Disk /dev/mapper/cryptswap1: 16.0GB
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 16.0GB 16.0GB linux-swap(v1)
