With ubuntu 19.10 I have been attempting to pair my Airpods with my laptop. There seems to be a problem with pairing and system is unable to add them as Bluetooth device. This happened after an upgrade from 19.04. Changing ControllerMode in /etc/bluetooth/main.conf seems to have no affect. Any help appreciated.
Samuel Zachara
  • 61
Try adding ControllerMode = bredr to /etc/bluetooth/main.conf file. Restart bluetooth service using the following command sudo systemctl restart bluetooth. Then try repairing with airpods, this worked for me in 19.10.
rahduro
  • 119
The bluetooth GUI didn't work and ControllerMode did nothing for me. I couldn't get it to pair, I just 'connected' in bluetoothctl and it worked. I fixed it like this:
Start the bluetooth controller in terminal
bluetoothctl
Inside the bluetoothctl, list the devices that it detects
devices
Find your device. The number XX:XX:XX:XX:XX:XX is the name of your device to Ubuntu. Forget about the text "Airpods" or whatever, that just helps you find your number.
Trust your device
trust XX:XX:XX:XX:XX:XX
Then just connect it
connect XX:XX:XX:XX:XX:XX
I'm not sure if trusting did anything, but I know it was not trusted before because I ran info XX:XX:XX:XX:XX:XX and it told me. Not sure if I was already paired or not. Not sure if Airpods were in pairing mode when I connected. Connecting just worked. My ControllerMode is still the default. Type help in bluetoothctl to mess around with it. Ubuntu 20.04
sammy
  • 171
I had the same problem. Changing ControllerMode doesn't work.
I Noticed that clicking airpod device to connect makes other devices unavailable to click and Bluetooth manager freezes.
Try to reload Bluetooth service then click connect again and airpods will appear as connected device.
sudo service bluetooth restart
Connected airpods
danjjl
  • 6,573
