When I ssh into my Ubuntu 18.04 box I get the motd
1 update could not be installed automatically
Which goes on to tell me to check the unattended-upgrades log.
The log shows no problems. How can I clear this bogus message?
OK, it wasn't bogus.
Turns out the script
/etc/update-motd.d/92-unattended-upgrades
produces this message at login.
This script references
/usr/share/unattended-upgrades/update-motd-unattended-upgrades
which in turn looks at the contents of
/var/lib/unattended-upgrades/kept-back
In my case this last file was non-blank because unattended-upgrades tried to update vino, which I have pinned to an old version on this Lubuntu box, because the latest version removes the options dialog.
Deleting /var/lib/unattended-upgrades/kept-back made the message go away - but only till the next time unattended-upgrades ran.
But there was nothing in the logs that it told me to reference about it!!
I'm not sure if this it the right way, but after I saw this discussion, I found there was NO kept-back file in /var/lib/unattended-upgrades/ in my environment.
Thus, I tried making the kept-back file.
sudo touch /var/lib/unattended-upgrades/kept-back
sudo reboot
Then,
0 update could not be installed automatically
appeared instead of
20 update could not be installed automatically
(In my case, the number was 20, not 1.) Then, I tried unattended-upgrades and rebooted again as below.
sudo unattended-upgrades
sudo reboot
After this, the 20 update could not be installed automatically message never appears.
