locate command is the fastest
The locate command is your friend in this case:
$ time locate "/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*/*"
/mnt/clone/home/rick/.gradle/wrapper/dists/gradle-4.6-all/bcst21l2brirad8k2ben1letg/gradle-4.6/samples/userguide/multiproject/dependencies/java/services/personService/src/main/java/org/gradle/sample/services/PersonService.java
/mnt/clone/home/rick/.gradle/wrapper/dists/gradle-4.6-all/bcst21l2brirad8k2ben1letg/gradle-4.6/samples/userguide/multiproject/dependencies/java/services/personService/src/test/java/org/gradle/sample/services/PersonServiceTest.java
/mnt/clone/home/rick/.gradle/wrapper/dists/gradle-4.6-all/bcst21l2brirad8k2ben1letg/gradle-4.6/samples/userguide/multiproject/dependencies/javaWithCustomConf/services/personService/src/main/java/org/gradle/sample/services/PersonService.java
/mnt/clone/home/rick/.gradle/wrapper/dists/gradle-4.6-all/bcst21l2brirad8k2ben1letg/gradle-4.6/samples/userguide/multiproject/dependencies/javaWithCustomConf/services/personService/src/test/java/org/gradle/sample/services/PersonServiceTest.java
real 0m1.731s
user 0m1.653s
sys 0m0.072s
Stuff in enough /*/* until no results are displayed, then subtract one /* to get the deepest subdirectory level. The files in the deepest levels will also be display.
Note: On this machine there are four different paths returned. Each path contains one file.
Some details about locate
The database used by locate is updated daily by cron. If you installed an application or created new directories today you need update the database using:
sudo updatedb
In Ubuntu 19.10 the locate command is no longer installed by default. Hopefully it returns in 20.04 but in the meantime you need to install it with:
sudo apt install mlocate
To gain an appreciation of locate speed look at what it has indexed for instant retrieval:
$ locate -S
Database /var/lib/mlocate/mlocate.db:
381,154 directories
2,548,775 files
213,049,136 bytes in file names
92,287,412 bytes used to store database
Using a script
Comments point out how people won't know the starting point. I wrote a script that defaults to 50 level starting point and works backwards from there. You can override with a starting point of 6 to 126 subdirectory levels.
Script output:
$ time deepdir
Search point 50 levels deep: //////////////////////////////////////////////////
Common path followed by unique sub-paths (deepest subdir 25 levels):
+- /mnt/clone/home/rick/.gradle/wrapper/dists/gradle-4.6-all/bcst21l2brirad8k2ben1letg/gradle-4.6/samples/userguide/multiproject/dependencies/
|--- /java/services/personService/src/main/java/org/gradle/sample/services/PersonService.java
|--- /java/services/personService/src/test/java/org/gradle/sample/services/PersonServiceTest.java
|--- /javaWithCustomConf/services/personService/src/main/java/org/gradle/sample/services/PersonService.java
|--- /javaWithCustomConf/services/personService/src/test/java/org/gradle/sample/services/PersonServiceTest.java
real 0m45.141s
user 0m44.552s
sys 0m0.588s
$ time deepdir 26
Search point 26 levels deep: //////////////////////////
(... SNIP repeated parts ...)
real 0m6.123s
user 0m6.041s
sys 0m0.080s
- The first time you run the script you don't know how deep the subdirectories go. Therefore the default of 50 levels will takes 43 seconds to run.
- The second time you run the script pass the known count + 1 and it only takes 6 seconds to run.
- After the second time, take the output line of
/*/*.../* and copy it (less 1 set) to the clipboard as a parameter for calling locate or another command.
The bash script
#!/bin/bash
PATH: $HOME/askubuntu/
DESC: Answer for: https://askubuntu.com/questions/1187624/how-to-quickly-find-the-deepest-subdirectory/1187625?noredirect=1#comment1985731_1187625
DATE: November 11, 2019.
StartLevel=50
[[ $1 != "" ]] && StartLevel="$1"
[[ $StartLevel -gt 126 ]] && { echo Max levels 126 ; exit 1 ; }
[[ $StartLevel -lt 6 ]] && { echo Min levels 6 ; exit 2 ; }
Big="/////////////////////////////////" # 33
Big="$Big///////////////////////////////" # 31
# Total supported: 126
If starting level populated it is too small.
Search="${Big:0:StartLevel*2}"
echo "Search point $StartLevel levels deep: $Search"
Count=$(locate "$Search" | wc -l)
[[ $Count -gt 0 ]] && { echo "Levels too small. $Count files found" ; exit 3 ; }
Loop backwards to find first populated level, always more than 5
for (( l=StartLevel; l>5; l-- )) ; do
Search="${Big:0:l*2}"
[[ $Count -gt 0 ]] && break
done
Arr=( $(locate "$Search") )
Enhancement using Q&A: Longest common prefix of two strings in bash
https://stackoverflow.com/a/17475354/6929343
Common=
"$(IFS=$'\n'; sed -e '$!{N;s/^(.).\n\1.$/\1\n\1/;D;}' <<<"${Arr[]}")"
Common="${Common%/*}/"
echo "Common path followed by unique sub-paths (deepest subdir $l levels):"
echo "+- $Common"
Len="${#Common}"
for p in "${Arr[@]}" ; do
# echo "DEBUG: $p"
Curr="$(dirname "$p")"
[[ $Curr != "$Last" ]] && echo "|--- /${p:$Len}"
Last="$Curr"
done
exit 0
