I'm trying to install node.js version 12 on my Ubuntu 19.10 laptop by following the instructions here.
When I execute the curl command I get an error about a locked directory:
$ curl -sL https://deb.nodesource.com/setup_12.x | bash -
## Installing the NodeSource Node.js 12.x repo...
## Populating apt-get cache...
+ apt-get update
Reading package lists... Done
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
Error executing command, exiting
I've looked to see if there's an apt-get task and rebooted my machine, but no joy.
Does anyone have a suggestion on how to get past this?
duffymo
  • 299
"Permission denied" usually means you're not root. But you always need superuser rights to install software.
Try this:
> curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
Notice the | sudo bash command at the end. That will run the install script as root.
