How to put YAD form fields value into variable after submit?
My script actually looks like this:
#!/bin/bash
default_jpg='/';
default_mp3='/';
default_resolution='1920:1080';
default_filename="/";
OUTPUT=$(yad \
--title="JPG and MP3 to MP4" \
--form \
--text="Options" \
--separator="," \
--field="JPG:FL" \
--field="MP3:FL" \
--field="Resolution" \
--field="MP4 (Output):SFL" \
--button="Create MP4":1 \
"$default_jpg" \
"$default_mp3" \
"$default_resolution" \
"$default_filename" \
) accepted=$?
if ((accepted == 1)); then
jpgfile=$( awk -F, '{print $1}' <<<$OUTPUT)
mp3file=$( awk -F, '{print $2}' <<<$OUTPUT)
resolution=$(awk -F, '{print $3}' <<<$OUTPUT)
filename=$( awk -F, '{print $4}' <<<$OUTPUT)
echo $jpgfile $mp3file $resolution $filename
fi
I fail to put the values of the form fields into variable. If this would work instead of just echoing the variables I would like to use them in this command:
ffmpeg -r 1 -loop 1 -i "$jpgfile" -i "$mp3file" -acodec copy -r 1 -shortest -vf scale=$resolution "$filename"
Please tell me what is wrong :(
