I am with problems on grub boot initializer.
When I go install the boot-repair via live CD to Ubuntu 19.10, I am getting the follow error.
ubuntu@ubuntu:~$ sudo apt install boot-repair
Reading package lists... Done
Building dependency tree
 boot-repair : Depends: boot-sav but it is not going to be installed
ubuntu@ubuntu:~$
Can anyone help me?
Andre Leoni
  • 151
Some of the dependencies are from the universe repository. Enable it and then try again:
sudo add-apt-repository universe
Try sudo fix broken packages first. It may not work though.
I've had broken packages and this didn't work. On another PC it worked though. I really don't understand why that was.
Joepie Es
  • 1,570
