Problem
I just received the Nvidia laptop I ordered specifically for coding and deep learning. So I just erased Windows while installing Ubuntu.
The installation procedures follow Ubuntu community listed below.
I initially thought there would be no much pain since I do not need dual boot (as I said, I ordered this machine solely for coding and deep learning). However, I am get stuck in purple screen that looks like enter image description here
It seems that this issue is releated to Nvidia GPU driver, which governs the display. However, all the workarounds I could find assume users could access GRUB, which is not my case since I erased Windows.
Could some help me? Thank you in advance!
Update
I would like to clarify several things
  • I burned the USB correctly, and could see GRUB like the following, and finally could boot into USB by setting nouveau.modeset=0 enter image description here enter image description here
  • I completed all the steps in the Ubuntu installation and probably installed it correctly.
  • After the Ubuntu installation, I tried to reboot the machine but initially it is all purple, and then the image shown before.
Mr.Robot
  • 113
An Ubuntu image is a "live" iso, so "burned" on a stick you can first check if it starts, without installing anything. So that's what I would do:
  • Take the correctly "burned" usb stick and put it into an usb slot. Power up the machine and "tell" the bios from where to boot (..the usb stick)
  • if you can't see the initial Ubuntu screen you may see an error message.Then your Iso hasn't been saved correctly
  • if you can see that screen, start Ubuntu - but thats a sure sign that linux can cope with your graphics card. If installed Ubuntu usually uses the non proprietary nouveau driver. It might lag and looks grizzly. Now you would have to install the correct nvida driver for your card.
Maybe you did all these things, but didn't tell ;-). Then you probably installed an nvidia driver that is not working for your laptop
kanehekili
  • 7,426
