How can I install the driver for my Epson WF-2830 printer on Ubuntu 16.04?
I know this has been discussed in numerous posts from 2013 thru 2018. Most of them seem to revolve around tricking the OS into loading an LSB package from an earlier Ubuntu release. I have spent hours trying several of them, without success. Does anyone know:
  1. Was there ever a final resolution?
  2. Where can I find it?
After doing sudo apt install -f
sudo dpkg -i epson-inkjet-printer-escpr_1.7.5-1lsb3.2_i386.deb
Selecting previously unselected package epson-inkjet-printer-escpr:i386.
(Reading database ... 261831 files and directories currently installed.)
Preparing to unpack epson-inkjet-printer-escpr_1.7.5-1lsb3.2_i386.deb ...
Unpacking epson-inkjet-printer-escpr:i386 (1.7.5-1lsb3.2) ...
dpkg: dependency problems prevent configuration of epson-inkjet-printer-escpr:i386:
 epson-inkjet-printer-escpr:i386 depends on lsb (>= 3.2).
dpkg: error processing package epson-inkjet-printer-escpr:i386 (--install):
 dependency problems - leaving unconfigured
Output of uname -a
Linux phil-ThinkPad-linux 4.15.0-66-generic #75~16.04.1-Ubuntu SMP Tue Oct 1 14:01:08 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Reason for using 386 version of driver, the only 64 bit version is AMD, and I was unsure if this would work on Intel.
Pilot6
  • 92,041
Phil N
  • 15
You are trying to install a wrong driver. i386 is intended for 32-bit systems, you have a 64-bit system.
The problem can be fixed this way:
  1. Remove the wrong driver
    sudo apt purge epson-inkjet-printer-escpr:i386
  2. Download the epson-inkjet-printer-escpr_1.7.5-1lsb3.2_amd64.deb file.
  3. Install it using dpkg -i.
All should work.
Regarding amd64 and Intel CPU see Difference between the i386 download and the amd64?
All packages installed in your system are amd64 except some specifically intended for 32-bit processes.
Pilot6
  • 92,041
