I have an HP Pavilion 15 cx-0144tx laptop. It is having 128 GB SSD and 1 TB HDD, having windows10 preinstalled (obviously on 128GB SSD), I wanted to dual boot it with Ubuntu 18.04, by partitioning using windows disk management. I made 300GB Unallocated from 1TB HDD. As I wanted to install ubuntu on 1TB HDD by giving 300GB to ubuntu. Then I booted my laptop from live USB of Ubuntu and chose "something else"(when it asks about installation type). And then I chose "free space" of 300GB* and made the following partitions:
  1. First partition : Size: 30 GB
    Type: Logical
    Location for the new partition: Beginning of the space
    Use as: Ext4 Journaling File system
    Mount Point:/
  2. Second partition : Size : 11 GB
    Type: Logical
    Use as: swap area
  3. Third partition : Size: Remaining all (around 260 GB)
    Type: Logical
    Mount Point : /home
Then, there was an option named "Device for boot loader installation", I got stuck there. The default option selected was my 128GB SSD, I didn't change it and then installed the Ubuntu. Now after installation, when I restarted the laptop, very strange lines in CLI appeared and laptop hanged. In short, I can't boot ubuntu now. But I can use windows.
So, why didn't ubuntu loaded successfully? I think I have made mistake in choosing the boot loader location, as it is located in SSD but all other system files are in HDD.
Now, what should I do if I to delete the boot loader from 128GB SSD and wanted to have it in a separate partition in 1TB HDD? Is it a better option to delete all the files related to ubuntu from windows disk management and to remove ubuntu bootloader from SSD and then again do the whole process by locating bootloader in HDD this time? Yes, then how to remove all the files related to ubuntu? Now, if I show the partitions in my windows disk manager it shows the partitions properly, but an EFI file is shown extra in HDD, how to remove it(as other partitions can be deleted but not this one)?
By making a partition for the bootloader in HDD, will my problem be solved?
Last doubt, I allocated around 310GB (not exactly 300) for Ubuntu using windows disk management initially. But when I saw the free space in the Ubuntu partition menu it was around 325GB, why does it show increased?
Thanks in advance. Screenshot of my present disk partitions
