I use an iPad 9.7" and it doesn't charge when connected to USB of my recently purchased Ubuntu 19.10 PC, an Asus Vivobook X509UA. I've gone through some questions here and they are mostly quite old. The latest one suggested to install ipad-charge that can be found here but is itself 4 years old and I suspect it's no longer being supported for newer version of Ubuntu.
I've tried the steps provided in the link:
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install ipad-charge
But I get these errors:
E: The repository 'http://ppa.launchpad.net/heathbar/ipad-charge/ubuntu eoan Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Any other alternative to charge my iPad at normal rate?
Edit: My machine has 4 USB ports, two are USB 2.0 ports, one is a small USB 3.1 Gen 1 Type-C port while the last is a USB 3.1 Gen 1 port. Tried charging on standard USB 2.0 ports but doesn't charge at normal rate. The one which is a USB 3.1 port also does not fully charge the device.
K7AAY
  • 17,705
Shiv_90
  • 304
  • 14
