after install some PPAs when ever I do sudo apt-get update the output is
Hit:1 http://au.archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://repo.steampowered.com/steam precise InRelease
Hit:3 http://au.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:4 http://au.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:5 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:6 http://ppa.launchpad.net/grumbel/ppa/ubuntu bionic InRelease
Hit:7 http://ppa.launchpad.net/kelleyk/emacs/ubuntu bionic InRelease
Err:8 http://ppa.launchpad.net/grumbel/ppa/ubuntu bionic Release
  404  Not Found [IP: 91.189.95.83 80]
Get:9 https://qgis.org/ubuntu bionic InRelease [3,693 B]
Err:9 https://qgis.org/ubuntu bionic InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 51F523511C7028C3
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/grumbel/ppa/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: https://qgis.org/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 51F523511C7028C3
E: The repository 'https://qgis.org/ubuntu bionic InRelease' is not signed.
lucas
  • 31
The grumbel ppa does not show any packages for bionic. When you look at the launchpad page for this ppa, under "Overview of published packages" there is a filter where you can select the Ubuntu version and bionic is not listed.
You can delete this ppa by running the following command:
sudo rm /etc/apt/sources.list.d/grumbel*
Also, I don't know how you installed the qgis.org repository so you will have to do one of the following.
First, if you have a file in /etc/apt/sources.list.d for this repository, edit the file and change "ubuntu" to "debian", save the file and then run: sudo apt update.
However, if you edited your /etc/apt/sources.list file to add this repository, edit this file and on the qgis.org repository line, change "ubuntu" to "debian". and then run: sudo apt update
Click here for more information on installing the qgis.org repository.
Alternatively, you can remove the offending ppas in Software&Updates.
mchid
  • 44,904
  • 102
  • 162
