Does anyone else have a laggy mouse when connecting the mouse normally via the bluetooth settings? It used to work fine for me until some updates a while ago. Now I have to use the Logitech Unifying Receiver which is annoying. Under Fedora Gnome this did not happen, only under the most recent Ubuntu and Debian 10 stable.
dave
  • 23
I had the same problem. Following Annatar's answer in Bluetooth mouse is laggy (low poll rate...) in 18.04 worked for me:
  1. Edit the following file:
    sudo nano /var/lib/bluetooth/xx\:xx\:xx\:xx\:xx\:xx/yy\:yy\:yy\:yy\:yy\:yy/info
    where xx:xx.... is the Bluetooth address of the PC and yy:yy... is the Bluetooth address of the mouse.
  2. In the file, add this section at the end:
    [ConnectionParameters]
    MinInterval=6
    MaxInterval=7
    Latency=0
    Timeout=216
  3. Then, restart the Bluetooth service with:
    systemctl restart bluetooth
