I install new kernel (from launchpad mainline kernel) in my Ubuntu 12.04, in order to test some issues I'm having.
Now, older kernels don't appear in the list at boot, just the new kernel. I can boot from the old kernel changing boot parameters at grub time, but I rather like to have a list entry I can select.
Jorge Castro
  • 73,717
Are the older ones not in the Previous kernel list? Assuming you have recovery mode - that would be the third menu entry.
Check that they actually exist in the grub.cfg file
cat /boot/grub/grub.cfg  |grep menuentry
For Grub (nor Grub2) edit /boot/grub/menu.lst
gksu gedit /boot/grub/menu.lst
Search for this line howmany . If doesn't exists, add it: The value holds the amount of kernals are shown on the boot menu.
 # howmany=all
Update GRUB afterwards
sudo update-grub
Tweak Grub
Tweak Grub 2
OrangeTux
  • 5,275
