I can't install any updates due to this disk space problem. Having reviewed various blog posts on this subject, I've understood that it has something to do with an accumulation of old kernels, but the solutions are not straightforward. Can anyone guide me to a tailor-made solution for my system (Ubuntu 16.04 LTS) ?
Output of sudo parted:
Model: ATA HITACHI HTS72323 (scsi)
Disk /dev/sda: 320GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type      File system  Flags
 1      1049kB  256MB  255MB  primary   ext2         boot
 2      257MB   320GB  320GB  extended
 5      257MB   320GB  320GB  logical                lvm
Model: Linux device-mapper (linear) (dm)
Disk /dev/mapper/ubuntu--vg-swap_1: 4148MB
Partition Table: loop
Disk Flags:
Number  Start  End     Size    File system     Flags
 1      0,00B  4148MB  4148MB  linux-swap(v1)
Disk /dev/mapper/ubuntu--vg-root: 316GB
Disk Flags:
 1      0,00B  316GB  316GB  ext4
df -h | grep -v loop
udev 1,9G 0 1,9G 0% /dev
tmpfs 382M 11M 371M 3% /run
 /dev/mapper/ubuntu--vg-root 290G 165G 111G 60% /
tmpfs 1,9G 110M 1,8G 6% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 1,9G 0 1,9G 0% /sys/fs/cgroup
/dev/sda1 236M 161M 64M 72% /boot
cgmfs 100K 0 100K 0% /run/cgmanager/fs
tmpfs 382M 68K 382M 1% /run/user/1000
@guiverc @mikewhatever @N0rbert @karel @vanadium
thanks for pointing out that an answer exists. I have read that answer but I wasn't confident about following the instructions, so I would appreciate one of you walking me through what needs to be done.
Mons
  • 279
