I am new to ubunutu and am trying to use some scientific software, namely pymatgen and phonopy. When running phonopy I get the following output. I tried to then update all of my packages, including python, but when I performed apt-get update I get the following output and errors below. Should I just reinstall ubuntu or python?
Phonopy errors
Traceback (most recent call last):
  File "/usr/lib/command-not-found", line 28, in <module>
    from CommandNotFound import CommandNotFound
  File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 19, in <module>
    from CommandNotFound.db.db import SqliteDatabase
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/db.py", line 5, in <module>
    import apt_pkg
ModuleNotFoundError: No module named 'apt_pkg'
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook
    from apport.fileutils import likely_packaged, get_recent_crashes
  File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in <module>
    from apport.report import Report
  File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module>
    import apport.fileutils
  File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module>
    from apport.packaging_impl import impl as packaging
  File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 24, in <module>
    import apt
  File "/usr/lib/python3/dist-packages/apt/__init__.py", line 23, in <module>
    import apt_pkg
Original exception was:
    import apt_pkg
apt-get update errors
Hit:2 http://repository.spotify.com stable InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Hit:4 http://archive.canonical.com/ubuntu bionic InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:6 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:7 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Get:1 https://github.com/cmsi/MateriAppsLive/wiki/UsingMateriAppsInDebianWheezy-en bionic InRelease
Err:1 https://github.com/cmsi/MateriAppsLive/wiki/UsingMateriAppsInDebianWheezy-en bionic InRelease
  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
  File "/usr/lib/cnf-update-db", line 8, in <module>
    from CommandNotFound.db.creator import DbCreator
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 11, in <module>
    import apt_pkg
    import apt
    import apt_pkg
    import apt_pkg
Reading package lists... Done
E: Failed to fetch https://github.com/cmsi/MateriAppsLive/wiki/UsingMateriAppsInDebianWheezy-en/dists/bionic/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: The repository 'https://github.com/cmsi/MateriAppsLive/wiki/UsingMateriAppsInDebianWheezy-en bionic InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
NKUP
