After upgrading from Ubuntu 19.04 to Ubuntu 19.10, my VPN connection doesn't work anymore.
My settings:
phase1: 3des-sha1;modp1024
phase2: 3des-sha1
This worked fine so far.
I checked the packages installed:
network-manager-l2tp 1.2.10-1;
network-manager-l2tp-gnome 1.2.10-1;
xl2tpd 1.3.12-1.1
libreswan 3.29-2
What can I do?
zx485
  • 2,865
Apparently, Ubuntu is not really happy with using 3des as handshake cipher, but I managed to make it work.
You may want to set the phase 1 and 2 algorithms using a final exclamation mark, like so:
Phase 1: 3des-sha1-modp1024! Phase 2: 3des-sha1!
I tested this with network-manager-l2tp 1.2.10-1, network-manager-l2tp-gnome 1.2.10-1 and Ubuntu 19.10
Hope this solves your issue too.
Regards.
I had the exact same problem upgrading from 19.04 to 19.10. I tried the NetworkManager upgrade too, but that didn't solve my problem. I then did the following three things, and now everything works again:
  1. Replaced libreSwan with StrongSwan (I found if I purged libreSwan, StrongSwan was automatically installed)
  2. Explicitly specified the Phase 1 and Phase 2 algorithms: "3des-sha1-modp1024" and "3des-sha1" respectively.
  3. Ensured only MSCHAPv2 was checked under PPP Settings.
I have a feeling #3 is what solved my problem as I did notice a few more authentication boxes were checked under PPP Settings after the upgrade.
Try the network-manager-l2tp 1.2.16-1 backport from the following PPA:
With network-manager-l2tp 1.2.16-1, you should be able to delete the phase 1 & 2 algorithm entries as it now uses a merge of proposals from Win10 and iOS instead of using the libreswan or strongswan default set of proposals.
