Ubuntu version
(base) vipulpopat@vipulpopat-XPS-13-9370:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 19.10
Release:    19.10
Codename:   eoan
(base) vipulpopat@vipulpopat-XPS-13-9370:~$ sudo apt install virtualbox-6.0
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 virtualbox-6.0 : Depends: libcurl3 (>= 7.16.2) but it is not installable
                  Depends: libpng12-0 (>= 1.2.13-4) but it is not installable
                  Depends: libvpx3 (>= 1.5.0) but it is not installable
                  Recommends: libsdl-ttf2.0-0 but it is not going to be installed
Can someone please help me out with this ?
Regards Vipul
singrium
  • 7,320
Vips
