I am using Ubuntu 19.10 in Asus X510UN. Using the lsusb command I can't find Fingerprint Device, and it's even showing no device found in fprintd-enroll. I have built-in fingerprint reader in my touchpad.
karel
  • 122,292
  • 133
  • 301
  • 332
Lucky Bairagi
  • 51
Is your device on this list? https://fprint.freedesktop.org/supported-devices.html
I see a lot of elantech devices on the list that are fprintd-enroll supported.
Other options instead of fprint look like fingerprint-gui https://launchpad.net/~fingerprint/+archive/ubuntu/fingerprint-gui
Which supports these devices: https://fprint.freedesktop.org/supported-devices.html
Or thinkfinger which is only think pads: http://www.thinkwiki.org/wiki/Integrated_Fingerprint_Reader#Software_support
I have a Lenovo L380 and am still looking for a package that supports my Synaptics fingerprint reader. I'm kind of a newbie myself so I'm still learning things but that is where I would start looking.
My Ubuntu not Even Showing that there is fingerprint reader in my Laptop... When i use lsusb in terminal it only shows about USB and other devices but Not Fingerprint.
Lucky Bairagi
  • 51
As Lucas suggests, check if your device is supported. If not, it might be under development at the fprintd project. You kernel might not show a fingerprint device, you could try a newer kernel to see if there is a difference.
To identify your device, check for any device ID in the lsusb output that has no name behind it.
Mine shows: Bus 001 Device 003: ID 27c6:538c Shenzhen Goodix Technology Co.,Ltd. Fingerprint Reader
It's showing the device but it does't work in fprintd-enroll either because no driver is loaded. If your device starts with 27c6 it's likely a Goodix too.
Check with that at the project page if a driver might be under development: https://gitlab.freedesktop.org/libfprint/libfprint/issues?scope=all&utf8=%E2%9C%93&state=opened&search=27c6 and if possible try to help out in any way.
With a bit of luck a driver may be coming from Dell, but that's not certain. A Goodix device is apparently in the Dell Precision 5530 and they support Linux on it, but it might be the model without that ( like in previous versions).
This suggests: https://certification.ubuntu.com/catalog/component/27c6:538c for example for this one: https://certification.ubuntu.com/hardware/201807-26295 that the mentioned fingerprint reader is supported by the 4.15 oem kernel.
You could try to build it from: https://code.launchpad.net/~canonical-kernel/ubuntu/+source/linux-oem/+git/bionic/+ref/oem or add the Dell repo to find the Dell shipped oem kernel.
I hope that helps!
Update 2020
If you need an official package, Upgrade to ubuntu 20.10, Fingerprint is now supported in the latest version Here
Alshoja
  • 191
