I am facing dependency issues while doing installation of rabbitmq-server through APT. I have 2 files added in /etc/apt/sources.list.d: bintray.rabbitmq.list and rabbitmq_rabbitmq-server.list
bintray.rabbitmq.list contains :
deb https://dl.bintray.com/rabbitmq/debian bionic erlang-22.1
deb https://dl.bintray.com/rabbitmq/debian bionic main
rabbitmq_rabbitmq-server.list contains:
deb https://packagecloud.io/rabbitmq/rabbitmq-server/ubuntu/ bionic main
deb-src https://packagecloud.io/rabbitmq/rabbitmq-server/ubuntu/ bionic main
I have Ubuntu 19.04 bionic.
 rabbitmq-server : Depends: erlang-base (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                            erlang-base-hipe (>= 1:21.3) but it is not going to be installed or
                            esl-erlang (>= 1:21.3) but it is not installable
                   Depends: erlang-crypto (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-eldap (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-inets (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-mnesia (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-os-mon (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-parsetools (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-public-key (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-runtime-tools (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-ssl (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-syntax-tools (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-tools (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                   Depends: erlang-xmerl (>= 1:21.3) but 1:20.2.2+dfsg-1ubuntu2 is to be installed or
                            esl-erlang (>= 1:21.3) but it is not<br> installable
$ apt-cache policy rabbitmq-server
rabbitmq-server:
  Installed: (none)
  Candidate: 3.8.0-1
  Version table:
        500 https://packagecloud.io/rabbitmq/rabbitmq-server/ubuntu bionic/main i386 Packages
     3.6.10-1 500
        500 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
        500 http://in.archive.ubuntu.com/ubuntu bionic/main i386 Packages
Zanna
  • 72,312
0coder
Ubuntu 19.04 has a different code name so I am going to assume that you meant to say you're using Ubuntu 18.04.
Carefully read these instructions. You have to pin the Erlang version and you probably shouldn't mix bintray and packagecloud resources.
The following Vagrantfile successfully installs the latest Erlang and RabbitMQ packages. You should be able to adapt it to your needs.
$script = <<SCRIPT
apt-get install -y sudo
apt-get update -y
apt-get install curl gnupg -y
curl -fsSL https://github.com/rabbitmq/signing-keys/releases/download/2.0/rabbitmq-release-signing-key.asc | sudo apt-key add -
apt-get install apt-transport-https
tee /etc/apt/sources.list.d/bintray.rabbitmq.list <<EOF
deb https://dl.bintray.com/rabbitmq-erlang/debian bionic erlang
EOF
apt-get update -y
apt-get install rabbitmq-server -y --fix-missing
date > /etc/vagrant_provisioned_at
SCRIPT
Vagrant.configure('2') do |config|
  config.vm.box = "ubuntu/bionic64"
  config.vm.hostname = 'UBUNTU-18-2'
  config.vm.provision 'shell', inline: $script
end
NOTE: the RabbitMQ team monitors the rabbitmq-users mailing list and only sometimes answers questions on StackOverflow.
Luke Bakken
  • 111
