I updated my ubuntu 19.04 to 19.10. After updating there are plenty of lagging occurs in few seconds every time.
Issue is the cursor and keys freezes for a few seconds, especially when trying to switch windows.
I have hybrid graphics (intel and AMD). I try to play with those settings but no luck.
Here are the details of it:
  1. This is not a performance issue, system monitor is showing that resource usage (CPU, RAM, Drive) is under control.
  2. The issue gets worse with Ethernet and WiFi
  3. The issue gets worse with dual monitors
Please suggest some steps to find the root cause of this.
As verified in comments the solution to lagging is to reboot into grub's Advanced Options for Ubuntu menu and select an older kernel.
Going forward try out each new kernel the system installs until one finally works properly. You can tell when a new kernel is being installed because update-initramfs and update-grub run with very unique output. Additionally you will see the new kernels on the grub Advanced Options for Ubuntu menu.
Make sure you do not autoremove the kernel that is working for you now. The only way you can autoremove it is to boot into a newer kernel and type:
sudo apt autoremove
So don't do that!
The problem is apparently caused by the swapping and disk writes in general. I found my solution by manually downgrading to kernel 5.2.21 from https://kernel.ubuntu.com/~kernel-ppa/mainline/
I'm now running it second day without problems. Micro freezes are gone and system is generally more responsive.
