Tried a lot of options described here, here, here and on other forums but neither worked for me .
Tried a number of grub parameters including acpi=force reboot=acpi as well as all sorts of reboot params as described in this answer.
There are no problems with reboot however, only with power off (system shuts down to a black screen and then I have to hold the HW shutdown button to switch the computer off)
Any suggestions/thoughts on how to fix this specific problem?
vir us
  • 151
UPDATE:
It appeared that this problem was caused by the fact that I've switched off the intel graphic driver with nomodset boot parameter while I was trying to fix laggish/screen redraw problem. I was able to fix the original problem with i915.enable_psr=0 boot parameter so no need for nomodset anymore and this problem went away. I'll leave it here anyways in case it might help someone.
ORIGINAL ANSWER:
This boot command finally fixed the problem for me:
pci=nommconf
Here is how one can add it:
  1. in terminal type sudo -i (enter root shell)
  2. then gedit /etc/default/grub
  3. Find the line: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
  4. Change to: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pci=nommconf"
  5. Save and close the file.
  6. again, in terminal update-grub
  7. and finally exit (to end the root shell)
Hope that helps someone
vir us
  • 151
