I saw during boot an error with something from selinux. So I searched for related packages on my System and found
libselinux1
I start a simulation with apt.
apt --dry-run purge libselinux1
NOTE: This is only a simulation!
apt needs root privileges for real execution.
Keep also in mind that locking is deactivated,
so don't depend on the relevance to the real current situation!
Reading package lists... Done
Building dependency tree
libxft2 : Depends: libfontconfig1 (>= 2.9.0) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Realy apt?
apt-cache policy libfontconfig1
libfontconfig1:
Installed: 2.12.6-0ubuntu2
Candidate: 2.12.6-0ubuntu2
Version table:
*** 2.12.6-0ubuntu2 500
500 http://archive.ubuntu.com/ubuntu bionic/main i386 Packages
100 /var/lib/dpkg/status
And
apt-cache policy libxft2
libxft2:
Installed: 2.3.2-1
Candidate: 2.3.2-1
Version table:
*** 2.3.2-1 500
Try update.
sudo apt update
[sudo] password for alex:
Hit:1 http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic InRelease
Hit:2 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://archive.canonical.com/ubuntu bionic InRelease
Get:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:5 https://dl.winehq.org/wine-builds/ubuntu bionic InRelease
Get:6 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:7 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Get:8 http://archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [597 kB]
Get:9 http://archive.ubuntu.com/ubuntu bionic-updates i386 Contents (deb) [34.1 MB]
Get:10 http://archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [984 kB]
Fetched 36.0 MB in 24s (1506 kB/s)
All packages are up to date.
Note no packages from winehq and from teejee2008 only uuku on my system.
Did I oversee something important?
No package in unclean state.
dpkg -l | egrep -v '^ii'
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
This Error is misleading. Some packages need libselinux1 like coreutils or smartmontools.
