I have been trying to Install 18.04.3 in dual boot mode. My latest attempt is to install on a USB memory stick of 128gb. The install ends with an error message basically saying "Cannot install Grub".
I ran the install from an Ubuntu Live USB stick with the main hard drive removed, so the only drive available for install was the 128gb USB.
The only success I have had is to an old Hard Drive running from a USB connection. However, there are errors even so and the performance is far too slow to be useable. Hence wish to run from a fast USB. An attempt to upgrade to Kernal 5 killed the working Ubuntu 18.04 I did have on a separate partition of the main drive.
Does anyone have any ideas to fix, please? PC Boot is via UEFI and the main drive (when connected) is a Samsung SSD which has Windows 10 on an encrypted drive.
ndchome
Did you crate "EFI Partition" when you installed Ubuntu?
This partition is where the installer will install grub during installation on a UEFI system, but without that partition, grub can't be installed. To solve this, you need to re-partition your drive.
Install Ubuntu again and create 1 partition at least 300 MB, then click the check boxes for "boot" and "esp".
I hope this helps you.
