I just installed Ubuntu 18.04 on a newly bought Thinkpad p53s; but every time I suspend the PC, it will suspend for one second and then immediately wake up.
I have tried multiple methods mentioned in various posts, e.g. link1, link2, link3. None of those solved my problem.
1) nothing is attached to its USB ports
2) Bluetooth is turned off
3) The nouveau driver is installed
4) Everything in /proc/acpi/wakeup is disabled.
It still wakes up immediately after going into suspend mode.
Here are the relevant log file from dmesg:
[ 987.097609] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[ 1468.175507] wlp0s20f3: deauthenticating from 94:10:3e:e4:01:96 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1469.577006] PM: suspend entry (deep)
[ 1469.577010] PM: Syncing filesystems ... done.
[ 1470.617407] rfkill: input handler enabled
[ 1470.662087] Freezing user space processes ... (elapsed 0.002 seconds) done.
[ 1470.664302] OOM killer disabled.
[ 1470.664303] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 1470.665927] printk: Suspending console(s) (use no_console_suspend to debug)
[ 1470.944969] e1000e: EEE TX LPI TIMER: 00000011
[ 1471.313851] ACPI: EC: interrupt blocked
[ 1471.393130] ACPI: Preparing to enter system sleep state S3
[ 1471.400448] ACPI: EC: event blocked
[ 1471.400448] ACPI: EC: EC stopped
[ 1471.400448] PM: Saving platform NVS memory
[ 1471.400467] Disabling non-boot CPUs ...
[ 1471.401716] smpboot: CPU 1 is now offline
[ 1471.402159] irq_migrate_all_off_this_cpu: 8 callbacks suppressed
[ 1471.402160] IRQ 157: no longer affine to CPU2
[ 1471.403176] smpboot: CPU 2 is now offline
[ 1471.404854] smpboot: CPU 3 is now offline
[ 1471.405369] IRQ 167: no longer affine to CPU4
[ 1471.406367] smpboot: CPU 4 is now offline
[ 1471.406981] IRQ 16: no longer affine to CPU5
[ 1471.406985] IRQ 126: no longer affine to CPU5
[ 1471.408003] smpboot: CPU 5 is now offline
[ 1471.408389] IRQ 127: no longer affine to CPU6
[ 1471.408392] IRQ 128: no longer affine to CPU6
[ 1471.409399] smpboot: CPU 6 is now offline
[ 1471.409803] IRQ 122: no longer affine to CPU7
[ 1471.409806] IRQ 124: no longer affine to CPU7
[ 1471.409813] IRQ 158: no longer affine to CPU7
[ 1471.409815] IRQ 159: no longer affine to CPU7
[ 1471.410830] smpboot: CPU 7 is now offline
[ 1471.415220] ACPI: Low-level resume complete
[ 1471.415321] ACPI: EC: EC started
[ 1471.415321] PM: Restoring platform NVS memory
[ 1471.416459] Enabling non-boot CPUs ...
[ 1471.416551] x86: Booting SMP configuration:
[ 1471.416553] smpboot: Booting Node 0 Processor 1 APIC 0x2
[ 1471.417308] cache: parent cpu1 should not be sleeping
[ 1471.417542] CPU1 is up
[ 1471.417560] smpboot: Booting Node 0 Processor 2 APIC 0x4
[ 1471.417953] cache: parent cpu2 should not be sleeping
[ 1471.418095] CPU2 is up
[ 1471.418110] smpboot: Booting Node 0 Processor 3 APIC 0x6
[ 1471.418505] cache: parent cpu3 should not be sleeping
[ 1471.418656] CPU3 is up
[ 1471.418671] smpboot: Booting Node 0 Processor 4 APIC 0x1
[ 1471.419145] cache: parent cpu4 should not be sleeping
[ 1471.419380] CPU4 is up
[ 1471.419398] smpboot: Booting Node 0 Processor 5 APIC 0x3
[ 1471.419789] cache: parent cpu5 should not be sleeping
[ 1471.419947] CPU5 is up
[ 1471.419962] smpboot: Booting Node 0 Processor 6 APIC 0x5
[ 1471.420354] cache: parent cpu6 should not be sleeping
[ 1471.420524] CPU6 is up
[ 1471.420539] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 1471.420938] cache: parent cpu7 should not be sleeping
[ 1471.421132] CPU7 is up
[ 1471.427249] ACPI: Waking up from system sleep state S3
[ 1471.517272] ACPI: EC: interrupt unblocked
[ 1471.578626] ACPI: EC: event unblocked
[ 1471.578800] iwlwifi 0000:00:14.3: RF_KILL bit toggled to enable radio.
[ 1471.825299] usb 1-6: reset full-speed USB device number 2 using xhci_hcd
[ 1471.906714] nvme nvme0: 8/0/0 default/read/poll queues
[ 1472.101638] usb 1-10: reset full-speed USB device number 5 using xhci_hcd
[ 1472.377603] usb 1-8: reset high-speed USB device number 3 using xhci_hcd
[ 1472.506767] psmouse serio1: synaptics: queried max coordinates: x [..5678], y [..4694]
[ 1472.541412] psmouse serio1: synaptics: queried min coordinates: x [1266..], y [1162..]
[ 1472.655073] usb 1-9: reset full-speed USB device number 4 using xhci_hcd
[ 1472.815039] acpi LNXPOWER:08: Turning OFF
[ 1472.816988] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[ 1472.818162] Bluetooth: hci0: Device revision is 2
[ 1472.818164] Bluetooth: hci0: Secure boot is enabled
[ 1472.818166] Bluetooth: hci0: OTP lock is enabled
[ 1472.818167] Bluetooth: hci0: API lock is enabled
[ 1472.818168] Bluetooth: hci0: Debug lock is disabled
[ 1472.818170] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 1472.818182] Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
[ 1472.820322] OOM killer enabled.
[ 1472.820324] Restarting tasks ... done.
[ 1472.854208] thermal thermal_zone6: failed to read out thermal zone (-61)
[ 1472.877302] pcieport 0000:00:1c.4: PCI bridge to [bus 02-3a]
[ 1472.877305] pcieport 0000:00:1c.4: bridge window [io 0x4000-0x5fff]
[ 1472.877308] pcieport 0000:00:1c.4: bridge window [mem 0xc0000000-0xd60fffff]
[ 1472.877310] pcieport 0000:00:1c.4: bridge window [mem 0x80000000-0xa1ffffff 64bit pref]
[ 1472.983171] PM: suspend exit
[ 1473.222701] rfkill: input handler disabled
[ 1473.303430] e1000e: enp0s31f6 NIC Link is Down
[ 1473.688309] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[ 1474.214211] Bluetooth: hci0: Waiting for firmware download to complete
[ 1474.214885] Bluetooth: hci0: Firmware loaded in 1366450 usecs
[ 1474.214952] Bluetooth: hci0: Waiting for device to boot
[ 1474.227984] Bluetooth: hci0: Device booted in 12786 usecs
[ 1474.227990] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
[ 1474.235035] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 1476.581191] wlp0s20f3: authenticate with 94:10:3e:e4:01:96
[ 1476.583340] wlp0s20f3: send auth to 94:10:3e:e4:01:96 (try 1/3)
[ 1476.622092] wlp0s20f3: authenticated
[ 1476.624795] wlp0s20f3: associate with 94:10:3e:e4:01:96 (try 1/3)
[ 1476.626157] wlp0s20f3: RX AssocResp from 94:10:3e:e4:01:96 (capab=0x411 status=0 aid=1)
[ 1476.629089] wlp0s20f3: associated
[ 1476.640478] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
cat /proc/acpi/wakeup | grep enabled shows:
GLAN S4 *enabled pci:0000:00:1f.6
XHC S3 *enabled pci:0000:00:14.0
RP01 S4 *enabled pci:0000:00:1c.0
RP05 S4 *enabled pci:0000:00:1c.4
PXSX S4 *enabled pci:0000:02:00.0
RP09 S4 *enabled pci:0000:00:1d.0
RP13 S4 *enabled pci:0000:00:1d.4
SLPB S3 *enabled platform:PNP0C0E:00
LID S4 *enabled platform:PNP0C0D:00
I disabled everything by echo XHC > /proc/acpi/wakeup.
What other reason can it be? I've tried all on I can find on the Internet. I've also tried Ubuntu 16.04 and Fedora 30, yet get the same problem.
Any help is greatly appreciated!! I don't want to install windows...
