I am attempting to use pyodbc to connect to a MSSQL database in python. I have installed the MS drivers following the instructions here using the 19.04 version. When attempting to install pyodbc via pip i get sql.h: No such file or directory. Googling tells me I need to install unixodbc and unixodbc-dev, however when I try to do just that I get the following message:
Reading package lists... Done
Building dependency tree
 unixodbc : Depends: odbcinst1debian2 (>= 2.3.7) but it is not going to be installed
            Depends: libodbc1 (>= 2.3.7) but it is not going to be installed
Running apt autoclean, apt install -f etc did not do anything.
niknoe
  • 173
It appears that there is a problem with the unixODBC that comes with the ODBC Driver on 19.10 (specifically one of the dependencies of the unixODBC that's provided with the driver depends on multiarch-support for some reason, which is present on all the other Ubuntus, but not on 19.10)
To get around that you can either download the package from http://www.unixodbc.org/ (see download button on right) and follow the instructions to install it manually. Or install the default unixODBC that is in the Ubuntu repo by doing the following:
#delete the package info, so that apt doesn't try to use that version of unixODBC
sudo rm /etc/apt/sources.list.d/mssql-release.list
#install the default one sudo apt install unixodbc
#re-add the package and install the driver sudo su curl https://packages.microsoft.com/config/ubuntu/19.04/prod.list > /etc/apt/sources.list.d/mssql-release.list exit sudo apt install msodbcsql17
Maxim
  • 256
