I've found that the msmtp package for Ubuntu 18.04 is old and missing a component. The current included package is version 1.6.6 from 2016-11-14 and is missing msmtpd. I would like to install version 1.8.6 from 2019-09-27 that is significantly updated and does include msmtpd.
What are the proper configuration arguments that would get this to compile with appropriate make install locations for Ubuntu 18.04?
Additionally, what would be the process for creating a quick /etc/init.d/ startup script for this so as to make sure that this service starts at boot-up and can be restarted easily?
A simle ./configure gives the following output, which appears to be missing TLS and I don't think /usr/local is the preferred folder from the other package's defaults:
Install prefix ......... : /usr/local
NLS support ............ : yes
TLS support ............ : no (Library: none)
IDN support ............ : yes (no library required)
GNU SASL support ....... : no (most likely unnecessary)
Libsecret support (GNOME): no
MacOS X Keychain support : no
Build msmtpd ............: yes
