31
I am doing my homework and I have a question about one line. I don't understand what this >&2 means:
if test -d $2
  then echo "$2: Is directory" >&2 ; exit 21
fi
File descriptor 1 is stdout and File descriptor 2 is stderr.
Using > to redirect output is the same as using 1>. This says to redirect stdout (file descriptor 1).
Normally, we redirect to a file. However, we can use >& to redirect to stdout (file descriptor 1) or stderr (file descriptor 2) instead.
Therefore, to redirect stdout (file descriptor 1) to stderr (file descriptor 2), you can use >&2.
For more information:
mchid
  • 44,904
  • 102
  • 162
11
It is simply displaying the message "/blah/blah/: Is directory" to stderr. Also known as Standard Error which is denoted by &2.
Without the &2 messages are displayed on stdout. Also known as Standard Output which is denoted by &1.
More details on displaying messages to &>2 can be found here:
In your command posted, both messages for stdout and stderr will appear on your terminal screen. However some applications will separate the stderr messages and perform special processing.
Most people don't bother redirecting echo error messages to >&2 but it is technically the correct way of doing things.
For more reading on stdin, stdout and stderr from user or system administrator perspective see:
For a programmers perspective of stdin, stdout, stderr which are &0, &1 and &2 respectively see:
So if test -d $2 Means if $2(the second argument) is a directory, then
echo "$2: Is directory" >&2 means print $2: is directory,
and >&2 means send the output to STDERR, So it will print the message as an error on the console.
You can understand more about shell redirecting from those references:
