After upgrade to 19.10 on my dual boot system I am unable to boot into Windows.
If I change boot order in the BIOS and put windows boot manager first I can boot into Windows no problem.
However... from the grub menu when I select Windows boot manager the screen flashes and I'm back at the grub menu. So I do see Windows as an option in grub, it just doesn't boot.
I used sudo grub-update
and boot-repair
here is the log: https://paste.ubuntu.com/p/rJPfP9WwSs/
DK Bose
  • 44,553
excuses
  • 63
The instructions on boot-repair report tell you to boot into Windows (as you do now by changing boot order) and then:
For example you can boot into Windows, then type the following command in an admin command prompt:
bcdedit /set {bootmgr} path \EFI\ubuntu\shimx64.efi
Do this from Windows and then if it doesn't work revise your question with current status / new issues.
Also note boot-repair created 7 custom entries to boot Windows and Ubuntu from UEFI. In my experience they won't all work. After you fix the booting issues see this answer:
Apparently this is a bug in Grub 2.04, which is shipped by Ubuntu 19.10.
See: https://bugs.launchpad.net/ubuntu/+source/grub2/+bug/1839317 https://bugs.launchpad.net/ubuntu/+source/grub2/+bug/1845289
You might consider either downgrading the version of Grub on your system or waiting for a fixed version.
