In the new version 19.10 my grub file is:
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=4
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
Despite this at boot I don't see the grub menu nor does it wait 4 seconds. How I can fix it?
Lilia
  • 395
Edit /etc/default/grub (sudo -H gedit /etc/default/grub)...
change:
to:
GRUB_TIMEOUT_STYLE=menu
then save the file and quit the editor. Next run:
sudo update-grub
GRUB_TIMEOUT_STYLE
If this option is unset or set to menu, then GRUB will display the menu and then wait for the timeout set by GRUB_TIMEOUT to expire before booting the default entry. Pressing a key interrupts the timeout.
If this option is set to countdown or hidden, then, before displaying the menu, GRUB will wait for the timeout set by GRUB_TIMEOUT to expire. If ESC is pressed during that time, it will display the menu and wait for input. If a hotkey associated with a menu entry is pressed, it will boot the associated menu entry immediately. If the timeout expires before either of these happens, it will boot the default entry. In the countdown case, it will show a one-line indication of the remaining time.
heynnema
  • 73,649
