I can't start Cheese Webcam Booth. It starts loading and there is a brief moment when the window shows up but then it disappears, like it shuts itself down and it's not in system monitor.
My webcam works perfectly in Skype video call. I installed and run Camorama and it gave me an error: Could not connect to video device (/dev/video0) Please check connection
When I run the lsusb I get this line for my webcam:
Bus 002 Device 002: ID 04f2:b210 Chicony Electronics Co., Ltd
And for my graphic card, running lspci:
VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
It's not a pressing matter, but it bugs my nerves, if it works on Skype, why does Cheese and other programs refuse to run. As I said, it's not a big deal but any help would be appreciated.
Running Cheese in terminal:
(cheese:11454): Gtk-WARNING **: Attempting to add a widget with type GtkImage to a GtkToggleButton, but as a GtkBin subclass a GtkToggleButton can only contain one widget at a time; it already contains a widget of type GtkLabel
(cheese:11454): Gtk-WARNING **: Attempting to add a widget with type GtkHBox to a GtkButton, but as a GtkBin subclass a GtkButton can only contain one widget at a time; it already contains a widget of type GtkLabel
(cheese:11454): Gtk-WARNING **: Attempting to add a widget with type GtkImage to a GtkButton, but as a GtkBin subclass a GtkButton can only contain one widget at a time; it already contains a widget of type GtkLabel
(cheese:11454): Gtk-WARNING **: Attempting to add a widget with type GtkHBox to a GtkToggleButton, but as a GtkBin subclass a GtkToggleButton can only contain one widget at a time; it already contains a widget of type GtkLabel
(cheese:11454): Gdk-WARNING **: The program 'cheese' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
  (Details: serial 932 error_code 9 request_code 137 minor_code 9)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
jrg
  • 61,707
I got the same errors, found bug reports everywhere. Did not feel like debugging software to take a snapshot.
I installed guvcview instead by running:
sudo aptitude install guvcview
Running guvcview worked out of the box for my Logitech, Inc. Webcam C200.
Michael
