Bit of a noob question, I know...
I want to batch convert my videos to h265, which I can do with the help of Zernity and ffmpeg, but I'm having a little problem with the progress bar, in that there isn't one.
The actual "meaty bit" works wonderfully, with or without the last part, which is:
zenity --pulsate --title "Processing " --text "${filename} " --pulsate --auto-close --auto-kill
The whole code is:
d1="$(zenity  --file-selection --title="Bulk Move    Choose starting directory"  --directory)"
d2="$(zenity  --file-selection --title="Bulk Move    Choose destination directory"  --directory)"
if [ "$?" != 0 ]; then
   exit
fi
for i in "$d1"/*
  do
## filter out the actual file name
  filename=$(basename -- "$i")
## the meaty bit
ffmpeg -i "$i" -c:v libx265 -preset medium -x265-params crf=28 -c:a aac -strict experimental -b:a 128k "$d2"/"${filename%.*}.mkv" ; done | zenity --pulsate --title "Processing " --text "${filename} " --pulsate --auto-close --auto-kill
The only way I know it's working is by either calling the script on a command line and watching the ffmpeg (very verbose) output, or monitoring CPU usage.
Can someone point me in the right direction?
Thanks
user256787
  • 39
You aren't checking if the starting directory was aborted only the destination directory. Also you can shorten if - then - fi like this:
[[ "$?" != 0 ]] && exit
This gives double the amount of abort checking with 1 less line of code.
To test the progress bar on any system use this:
$ for i in ./* ; do echo $i ; sleep .1 ;  done | zenity --pulsate --title "Processing " --text "${filename} " --pulsate --auto-close --auto-kill
--pulsate is not supported for this dialogue
Ah there is an error message! --progress is missing to tell zenity a progress bar is desired. So the working script would be:
d1="$(zenity  --file-selection --title="Bulk Move    Choose starting directory" \
    --directory)"
d2="$(zenity  --file-selection --title="Bulk Move    Choose destination     directory" \
    --directory)"
for i in "$d1"/* ; do
    ## the meaty bit
    ffmpeg -i "$i" -c:v libx265 -preset medium -x265-params crf=28 \
done | zenity --progress --pulsate --title "Processing " \
              --text "ffmpeg - convert files" \
Passing ${filename} to --text option will not update display with each file name processed. If you want this you will need to switch to yad (Yet Another Dialog) which is a super-charged version of zenity:
Although the source code appears in the .gif you can copy and paste in your own script from this Q&A:
