i am new in linux and want install node with bellow command:
sudo apt-get install curl
curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
sudo apt-get install nodejs
and angular 8 needs node 12.x
i remove node with sudo apt-get purge --auto-remove nodejs and run bellow command but it installed perverse version
sudo apt-get install curl curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash - sudo apt-get install nodejs
Mohsen Saleh
  • 121
  1. curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
  2. sudo apt install nodejs
  3. Check: $ node --version Output: v10.16.3
  4. Check: $ npm --version Output: 6.9.0
Try using n. After installing node in any way, eg. as described below:
sudo apt-get install -y nodejs
you should have npm available. Install n with:
npm install -g n
and select correct version
  • n lsr to list available versions
  • n latest to use latest
  • n 12.0.0 to use 12.0
kubahaha
  • 1,167
-1
Try the following command
sudo n lts
if you want to install update version then run command
sudo install n16.15.1
This work for me fine.
