Terminal reads
Dell-DM061:~$ sudo apt-get upgrade E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable) E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
Terminal reads
If you just started your system, it may be searching for updates which creates the lock. Make sure you have not another instance of apt, apt-get or aptitude running in the background:
ps aux | grep -e apt -e dpkg | grep -v grep
If this command return some process, like in this example where I'm running synaptic package manager as a test:
darent 5578 0.0 0.0 10948 968 ? S 16:24 0:00 /bin/sh /usr/bin/synaptic-pkexec
root 5579 20.0 1.0 814300 173360 ? Sl 16:24 0:03 /usr/sbin/synaptic
You may have two options. Wait until the process finishes (keep repeating the command until there's no output) or kill it taking note of the number and executing:
sudo kill 5578 5579
With the number of the proces or processes. This will kill the process in a "clean" way. If it refuses to exit, you can force it adding the switch -9 to the order:
sudo kill -9 5578 5579
But I'd recommend the first one just in case. Then, run the upgrade again:
sudo apt-get update && sudo apt-get upgrade
