I have exhausted all online solutions including boot-repair and sudo update-grub, but nothing works. Ubuntu itself is working fine. Details:
i - Lenovo IdeaPad V470
ii - Using Kingston SSD
iii - Windows 7 was already installed
iv - When installing Ubuntu 18.04.3 using USB, it did not detect Windows 7, so I carried on with manual partition.
v - I dedicated around 150 MB space for EFI in the manual partition.
Now GRUB doesn't ask for OS selection. Pressing Esc does take me to GRUB, but still, there is no Windows option. Only Ubuntu and advanced Ubuntu options appear on the menu.
The Windows is not configured to UEFI mode. In fact, I can't even switch from UEFI to Legacy mode.
EDIT: I am also attaching screenshot of setup. There is no option to switch between UEFI and Legacy modes.setup image
You can find more about my problem here in Pastebin (as long as the page doesn't expire).
http://paste.ubuntu.com/p/TMR6zZ5nSP/
Also, I am pasting a brief pastebin summary:
============================= Boot Info Summary: ===============================
 => Syslinux MBR (5.00 and higher) is installed in the MBR of /dev/sda.
 => Grub2 (v2.00) is installed in the MBR of /dev/sdb and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    for /boot/grub. It also embeds following components:
    modules
    fshelp ext2 part_msdos biosdisk search_fs_uuid
    config script
    search.fs_uuid 921378fa-e853-452f-a14a-0d06cd424be0 root hd0,msdos3
    set prefix=($root)'/boot/grub'
sda1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows 7/2008: NTFS
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /bootmgr /Boot/BCD
sda2: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:        /Windows/System32/winload.exe
sda3: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  Grub2 (v1.99-2.00)
    Boot sector info:  Grub2 (v1.99-2.00) is installed in the boot sector of
                       sda3 and looks at sector 218305592 of the same hard
                       drive for core.img, but core.img can not be found at
                       this location.
    Operating System:  Ubuntu 18.04.3 LTS
    Boot files:        /boot/grub/grub.cfg /etc/fstab
                       /boot/grub/i386-pc/core.img
sda4: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  -
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sda6: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  FAT32
    Operating System:
    Boot files:        /EFI/ubuntu/grub.cfg /EFI/BOOT/bootx64.efi
                       /EFI/BOOT/fbx64.efi /EFI/ubuntu/fwupx64.efi
                       /EFI/ubuntu/grubx64.efi /EFI/ubuntu/mmx64.efi
K7AAY
  • 17,705
