At boot/login two apps are launched in my system, and I need to control their positions on the screen.
I have installed compizconfig-settings-manager and found the Place Window option. But there my ignorance is too great to continue.
I have searched here, but unfortunately the tips and hints stop about where I also end up. 17.04 How to set default window screen position is a typical example.
My questions:
1. Which of the three alternatives should I use?
2. How do I define which window I want to position?
3. How do I calculate X and Y coordinates? Is (0,0) the upper left? How calculate coordinates for a window to be positioned in the lower right of my screen?
The reason for this three-fold question is the delicasy of my system; I dare not use trail-and-error on it.
jason
  • 111
A) How do I calculate X and Y coordinates?
Start from 0,0 (upper left) and move the desire number of pixels across for the first starting coordinate, then down for the second starting coordinate.
B) Is (0,0) the upper left?
Yes.
C) How (to) calculate coordinates for a window to be positioned in the lower right of my screen?
Your screen resolution minus one is the bottom right; if your screen is set to 1920x1280 then bottom right is (1919,1279). Subtract the size of the desired window from that value for the start coordinates; for example, if you want a 320x180 window positioned at bottom right, it would start at ((1919-320),(1279-180)) or (1599,1099). Don't forget, if you use a bottom panel, to offset for its height as well.
K7AAY
  • 17,705
In a thread on LinuxQuestions.org, Fixed Windows Placemnet Using CompizConfig I found a working howto. See the question by CVAlkan. It answered all my questions.
jason
  • 111
