Need help badly. I opened up Ubuntu, it needed an update run and I did that but I received an error message for 1 broken package. Opened up synaptic package manager to see that it was a package called linux-image-generic 4.15.0.65.67_amd64. So its new its the latest on Ubuntu's site. The error message is attached. I've tried complete removal through package manager and reinstall twice now. No go. Not sure what to do. Never had this problem before.
Thank you!
Error message detail after attempt at reinstallation
Update: tried running sudo apt-get install -f Result:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libllvm7 linux-headers-5.0.0-27 linux-headers-5.0.0-27-generic
linux-image-5.0.0-27-generic linux-modules-5.0.0-27-generic
linux-modules-extra-5.0.0-27-generic
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
linux-modules-extra-4.15.0-65-generic
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/32.9 MB of archives.
After this operation, 170 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
E: Invalid archive member header mu~|�0��ŵ a�d��Kj]�m��4���i�m�a\�8�a���<-�%g�Y}�0k�
E: Prior errors apply to /var/cache/apt/archives/linux-modules-extra-4.15.0-65-generic_4.15.0-65.74_amd64.deb
debconf: apt-extracttemplates failed: No such file or directory
(Reading database ... 402329 files and directories currently installed.)
Preparing to unpack .../linux-modules-extra-4.15.0-65-generic_4.15.0-65.74_amd64.deb ...
Unpacking linux-headers-4.15.0-65 (4.15.0-65.74) over (4.15.0-65.74) ...
Setting up linux-headers-4.15.0-65 (4.15.0-65.74) ...
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-modules-extra-4.15.0-65-generic; however:
Package linux-modules-extra-4.15.0-65-generic is not installed.
dpkg: error processing package linux-image-generic (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
linux-image-generic
ALSO: In the properties of the package in manager this is what I have:
Depends: linux-image-4.15.0-65-generic
Conflicts:linux-image-generic
