/etc/sudoers:
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults        env_reset
Defaults        mail_badpass
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
h ALL=NOPASSWD: /usr/bin/brightlight -i 20 -f /sys/class/backlight/amdgpu_bl0
But doing the command still gives me a permission error.
h@pop-os:~$ brightlight -i 20 -f /sys/class/backlight/amdgpu_bl0
brightlight: could not open "brightness" file: Permission denied
Also
h@pop-os:~$ sudo -l
Matching Defaults entries for h on pop-os:
    env_reset, mail_badpass, secure_path=/usr/local/sbin\:/usr/local/bin\:/usr/sbin\:/usr/bin\:/sbin\:/bin\:/snap/bin
User h may run the following commands on pop-os:
    (ALL : ALL) ALL
    (root) NOPASSWD: /usr/bin/brightlight -i 20 -f /sys/class/backlight/amdgpu_bl0
Things I have tried:
  • Rebooting
  • Creating a file in /etc/sudoers.d/brightlight with last line of config above
EDIT: Fixed, you need to add sudo, and it won't prompt you for a password
W. Reyna
  • 103
Your entry in /etc/sudoers means that you can run
sudo brightlight -i 20 -f /sys/class/backlight/amdgpu_bl0
without being asked for a password. It doesn't mean you can run
without sudo.
