I am trying to install CUDA in Ubuntu 18.04.3 LTS according to this documentation from nvidia.
I ran into trouble when I tried to install linux headers by the following command.
sudo apt-get install linux-headers-$(uname -r)
It raised an Unmet dependencies error.
libcuinj64-9.1 : Depends: libcuda1 (>= 387.26) or
libcuda-9.1-1
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
When I tried
sudo apt --fix-broken install
I got
dpkg: error processing archive /var/cache/apt/archives/libnvidia-compute-430_430.26-0ubuntu0.18.04.2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/x86_64-linux-gnu/libnvidia-ml.so', which is also in package nvidia-340 340.107-0ubuntu0.18.04.3
The whole terminal output can be seen here.
This is the gpu I have
*-display
description: VGA compatible controller
product: GM204 [GeForce GTX 970]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nouveau latency=0
resources: irq:29 memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:c0000-dffff
I am not sure where to go from here. Can anyone help?
