The 'canonical' abcde conf file section of the website at andrews-corner has been removed; what is a conf file that I can use now to rip my audio cds with abcde to multiple different formats at the same time under Ubuntu?
Disclaimer: This is my web site and I am a former developer of abcde...
andrew.46
  • 39,359
Disclaimer: This my web site and I am a former developer of abcde...
The web author of andrews-corner has moved to other areas of interest now but preserved here is an ~/.abcde.conf that will rip to 11 different audio formats at the same time:
# -----------------$HOME/.abcde.conf----------------- #
#  A sample configuration file to convert music cds to
#  MP3, Ogg Vorbis, FLAC, Musepack, AAC, WavPack, Opus,
#  Monkey's Audio (ape), True Audio, AC3 and mp2, 11 formats
#  at the same time! Using abcde version 2.7.2 release version.
#   Acknowledgements to http://andrews-corner.org
Encode tracks immediately after reading. Saves disk space, gives
better reading of 'scratchy' disks and better troubleshooting of
encoding process but slows the operation of abcde quite a bit:
LOWDISK=y
Specify the method to use to retrieve the track information,
the alternative is to specify 'musicbrainz':
CDDBMETHOD=cddb
With the demise of freedb (thanks for the years of service!)
we move to an alternative:
CDDBURL="http://gnudb.gnudb.org/~cddb/cddb.cgi"
Make a local cache of cddb entries and then volunteer to use
these entries when and if they match the cd:
CDDBCOPYLOCAL="y" CDDBLOCALDIR="$HOME/.cddb" CDDBLOCALRECURSIVE="y" CDDBUSELOCAL="y"
OGGENCODERSYNTAX=oggenc # Specify encoder for Ogg Vorbis MP3ENCODERSYNTAX=lame # Specify encoder for MP3 FLACENCODERSYNTAX=flac # Specify encoder for FLAC MPCENCODERSYNTAX=mpcenc # Specify encoder for Musepack AACENCODERSYNTAX=fdkaac # Specify encoder for AAC OPUSENCODERSYNTAX=opusenc # Specify encoder for Opus WVENCODERSYNTAX=wavpack # Specify encoder for Wavpack APENCODERSYNTAX=mac # Specify encoder for Monkey's Audio TTAENCODERSYNTAX=tta # Specify encoder for True Audio MP2ENCODERSYNTAX=twolame # Specify encoder for MP2 MKAENCODERSYNTAX=ffmpeg # Specify encoder for MKA (AC3 via FFmpeg)
OGGENC=oggenc # Path to Ogg Vorbis encoder LAME=lame # Path to MP3 encoder FLAC=flac # Path to FLAC encoder MPCENC=mpcenc # Path to Musepack encoder FDKAAC=fdkaac # Path to the AAC encoder OPUSENC=opusenc # Path to Opus encoder WVENC=wavpack # Path to WavPack encoder APENC=mac # Path to Monkey's Audio encoder TTA=tta # Path to True Audio encoder TWOLAME=twolame # Path to MP2 encoder FFMPEG=ffmpeg # Path to FFmpeg (AC3 via FFmpeg)
OGGENCOPTS='-q 6' # Options for Ogg Vorbis LAMEOPTS='-V 2' # Options for MP3 FLACOPTS='-s -e -V -8' # Options for FLAC MPCENCOPTS='--extreme' # Options for Musepack FDKAACENCOPTS='-p 2 -m 5 -a 1' # Options for fdkaac OPUSENCOPTS="--vbr --bitrate 128" # Options for Opus WVENCOPTS="-hx3" # Options for WavPack APENCOPTS="-c4000" # Options for Monkey's Audio TTAENCOPTS="" # Options for True Audio TWOLAMENCOPTS="--bitrate 320" # Options for MP2 FFMPEGENCOPTS="-c:a ac3 -b:a 448k" # Options for MKA (AC3 via FFmpeg)
OUTPUTTYPE="ogg,mp3,flac,mpc,m4a,opus,wv,ape,tta,mp2,mka" # Encode to 11 formats!
The cd ripping program to use. There are a few choices here: cdda2wav,
dagrab, cddafs (Mac OS X only) and flac. New to abcde 2.7 is 'libcdio'.
CDROMREADERSYNTAX=cdparanoia
Give the location of the ripping program and pass any extra options,
if using libcdio set 'CD_PARANOIA=cd-paranoia'.
CDPARANOIA=cdparanoia
CDPARANOIAOPTS="--never-skip=40"
Give the location of the CD identification program:
CDDISCID=cd-discid
Give the base location here for the encoded music files.
OUTPUTDIR="$HOME/Music"
The default actions that abcde will take.
ACTIONS=cddb,playlist,read,encode,tag,move,clean
Decide here how you want the tracks labelled for a standard 'single-artist',
multi-track encode and also for a multi-track, 'various-artist' encode:
OUTPUTFORMAT='${OUTPUT}/${ARTISTFILE}-${ALBUMFILE}/${TRACKNUM}.${TRACKFILE}' VAOUTPUTFORMAT='${OUTPUT}/Various-${ALBUMFILE}/${TRACKNUM}.${ARTISTFILE}-${TRACKFILE}'
single-track encode and also for a single-track 'various-artist' encode.
(Create a single-track encode with 'abcde -1' from the commandline.)
ONETRACKOUTPUTFORMAT='${OUTPUT}/${ARTISTFILE}-${ALBUMFILE}/${ALBUMFILE}' VAONETRACKOUTPUTFORMAT='${OUTPUT}/Various-${ALBUMFILE}/${ALBUMFILE}'
Create playlists for single and various-artist encodes. I would suggest
commenting these out for single-track encoding.
PLAYLISTFORMAT='${OUTPUT}/${ARTISTFILE}-${ALBUMFILE}/${ALBUMFILE}.m3u' VAPLAYLISTFORMAT='${OUTPUT}/Various-${ALBUMFILE}/${ALBUMFILE}.m3u'
This function takes out dots preceding the album name, and removes a grab
bag of illegal characters. It allows spaces, if you do not wish spaces add
in -e 's/ /_/g' after the first sed command.
mungefilename () { echo "$@" | sed -e 's/^.//' | tr -d ":><|/&quot;'?[:cntrl:]" }
MAXPROCS=2 # Run a few encoders simultaneously PADTRACKS=y # Makes tracks 01 02 not 1 2 EXTRAVERBOSE=2 # Useful for debugging COMMENT='abcde version 2.7.2' # Place a comment... EJECTCD=y # Please eject cd when finished :-)
Keep in mind that this ~/.abcde.conf can also be used for a single audio codec rip and encode by using something like the following:
abcde -o mp3
This will utilise the 'mp3' section of the conf file only... How cool is the command line :)
andrew.46
  • 39,359
Take a look here also..
A collection of abcde.conf files...
andrew.46
  • 39,359
Craig
  • 31
If you want start from a full list of configuration options and defaults, copy /etc/abcde.conf to ~/.abcde.conf and edit it.
Putting only OUTPUTTYPE="ogg,mp3,flac,mpc,m4a,opus,wv,ape,tta,mp2,mka" into that file will provide multiple file type outputs without changing any other configuration options.
