I have a fresh Ubuntu 18.04 installation on a Thinkpad W520 (16GB, Intel® Core™ i7-2640M CPU @ 2.80GHz, Nvidia Quadro 1000M):
- Windows 7 on
sda(original Win boot loader) - Ubuntu on
sdb(Linux boot loader installed onsdb5)
Since the beginning, I have to do at least 3 attempts before managing to boot Ubuntu. After searching a while for a solution, I installed the latest drivers. It didn't solved the problem. Now I have one of the following random outcome when trying to boot the system:
- Blank screen (same dark purple color as Ubuntu's grub)
- Black black screen
- Black screen with cursor on top left
Screen stuck on this message:
/dev/sdb5: recovering journal /dev/sdb5: clean, 233651/30531584 files, 5941895/122094848 blocksMessage as in (4) flashes for a while, then the system boots
- Systems boots regularly
Now that Ubuntu finally has booted, I'm examining the logs. I found the message:
ott 05 11:48:01 enea-ThinkPad-W520 nvidia-persistenced[790]: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/dev/nvidia*) exist, and that user 122 has read and write permissions for those files.
I can't figure out how to solve it. Now that the system has booted, the graphic card seems to work perfectly. However, if I try to reboot the system, again I have a 2 out of 3 chances it won't boot at all...
UPDATE:
Here I found the suggestion to set WaylandEnable=false in my gdm3/custom.conf. Elsewhere I found this should solve the issue due to an bug that occurs with the NVidia driver on older CPUs. Trying this change and rebooting again... Keeping my fingers crossed...
EDIT: Nothing changed after the previous suggestion. I only had to tried twice before being able to boot the system, but the problem is still there. I'm out of options...
