Starting to learn Nodejs in Ubuntu (New to ubuntu as well). when I use apt install nodejs , v8.x.x is getting installe instead of current v12.x.x. I tried to use nvm using from here but it is only installing node and not nodejs.
I tried to install from nodejs.org but it's just installing a tar package and I'm not sure how to install it or even if I'm able to install, do not find any easy way to update the node version.
Can someone provide me right way to install latest nodejs.
Thanks
Ran94
NodeJS provides instructions for installing the latest versions of Node through various package managers on their website.
For Node.js v12.x:
curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
sudo apt-get install -y nodejs
Use the commands below:
sudo n list => show the list of installed versions sudo n stable => install latest stable version.
sudo n <version number> (ex: sudo n 12.18.3) to install the specific version of nodejs
Additionally, you can also use nvm (especially in case of Windows os, because above commands works on Linux) to install or switch between node versions.
Artur Meinild
  • 31,035
Ubuntu now has Node.js in its default repositories that can be used to provide a consistent experience across multiple systems. you can install it via apt:
sudo apt update
sudo apt install nodejs
If the package in the repositories suits your needs, this is all you need to do to get set up with Node.js. In most cases, you’ll also want to also install npm, the Node.js package manager. You can do this by installing the npm package with apt as well:
sudo apt install npm
the build tools also avaiable here
sudo apt install build tools
