As this relates to an old version of ubuntu, I have now posted the question to serverfault.
I work on a server where the operating system is installed on an SSD but data storage is on internal harddrives set up in a RAID system. Recently I have been unable to mount the raid system when booting, while the operating system loads fine. I suspect technicians hit the server while it was running, due to scratches on the case but I am not sure.
When I boot the computer I get the error message The drive for /home is not ready or present (the same message for /Data and /Backup. I entered the recovery shell and ran fsck -A as suggested in the post here, but I get the message that / was busy.
I then booted into recovery mode and ran fsck -A, but I get the message that
fsck.ext4: Unable to resolve 'UUID=334eef34-16c4-45ec-9cc9-5f40e9f8207d'
fsck.ext4: Unable to resolve 'UUID=19bf1002-fa4b-4462-9ea6-807d5b0f312b'
fsck.ext4: Unable to resolve 'UUID=0f556fa7-b061-4c22-b84b-97e2e3f1b545'
At ubuntuforums I found the suggestion to edit /etc/fstab but I am out of my depth here as I do not really understand what I am messing with.
running blkid returns
/dev/sda1: UUID="7c05724f-61bd-4d70-b908-f6c83c4365b8" TYPE="ext4"
/dev/sda5: UUID="51978b9f-747b-4f41-8b2b-42f3da3347e6" TYPE="swap"
/dev/sdb1: UUID="65325870-b912-f8b1-af82-ab0c8bb94dbb" UUID_SUB="13151e15-3890-90d5-d910-8ab781fc713f" LABEL="CBMRubuntu:0" TYPE="linux_raid_member"
/dev/sdc1: UUID="65325870-b912-f8b1-af82-ab0c8bb94dbb" UUID_SUB="05322b31-8961-f57d-143b-877123c61d7c" LABEL="CBMRubuntu:0" TYPE="linux_raid_member"
/dev/sdd1: UUID="65325870-b912-f8b1-af82-ab0c8bb94dbb" UUID_SUB="85430436-4dfc-96ff-083c-0734a76ff8b6" LABEL="CBMRubuntu:0" TYPE="linux_raid_member"
/dev/sde1: UUID="65325870-b912-f8b1-af82-ab0c8bb94dbb" UUID_SUB="05feb9dd-9c4f-bc2f-50e7-c4422419268a" LABEL="CBMRubuntu:0" TYPE="linux_raid_member"
/dev/sdf1: UUID="65325870-b912-f8b1-af82-ab0c8bb94dbb" UUID_SUB="3ef48a37-14b5-1fc8-1eed-48eca24f0043" LABEL="CBMRubuntu:0" TYPE="linux_raid_member"
/dev/sdg1: UUID="65325870-b912-f8b1-af82-ab0c8bb94dbb" UUID_SUB="5960eff8-d60b-c206-90b9-c448723f9ef3" LABEL="CBMRubuntu:0" TYPE="linux_raid_member"
and running cat /etc/fstab prints
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda1 during installation
UUID=7c05724f-61bd-4d70-b908-f6c83c4365b8 /               ext4    errors=remount-ro 0       1
# /Backup was on /dev/md0p2 during installation
UUID=334eef34-16c4-45ec-9cc9-5f40e9f8207d /Backup         ext4    defaults        0       2
# /Data was on /dev/md0p1 during installation
UUID=19bf1002-fa4b-4462-9ea6-807d5b0f312b /Data           ext4    defaults        0       2
# /home was on /dev/md0p3 during installation
UUID=0f556fa7-b061-4c22-b84b-97e2e3f1b545 /home           ext4    defaults        0       2
# swap was on /dev/sda5 during installation
UUID=51978b9f-747b-4f41-8b2b-42f3da3347e6 none            swap    sw              0       0
I noticed that the missing UUIDs are the same as the ones in /etc/fstab/ but does not match the ones in blkid. Is there some way to figure out which UUIDs goes where and restore the file system?
The vast majority is backed up so the damage is not great, but there are a few things that would be nice to restore.
I work on a server with Ubuntu 14.04.5 LTS, if that makes a difference.
Lars
