I don't want to change the default colors as such, I want to use a custom color. For example I want to lighten the blue as it is too dark. I don't want to change it to a different color, but make it lighter. Is that possible in linux? I can change the colors running linux sub system in Windows using the command prompt properties and adjusting the RGB values of each color, but wanted a similar change in pure linux itself.
keys
  • 33
If I Understood your Question in a right way..
there is built in option in gnome-terminal under Edit-->Preferences-->Colors-->Use transparent background
graham
  • 13,061
