I followed the instructions in How to read and write HFS+ journaled external HDD in Ubuntu without access to OS X?
I used the command:
sudo mount -t hfsplus -o force,rw /dev/sdXY /media/mntpoint
The drive mounts in the directory I pointed it to. It works perfectly, but I would like to change the name of the directory. I failed in all conventional ways. I thought the path was stored in the fstab file but there I only have my NAS device. I am a Linux newbie. Hopefully, someone has a solution.
Eliah Kagan
  • 119,640
First, create a folder in any path you would like to:
$ sudo mkdir /home/mountpoint
Then just mount in this folder:
$ sudo mount -t hfsplus -o force,rw /dev/sdXY /home/mountpoint
And about the /etc/fstab file: it mounts devices automatically, but just if the deivce is connected to your computer in boot time!
Note: mount command ususaly identify the format, so you don't need to specify -t hfsplus, and for -o (options), it mounts rw, so all you need to do is:
$ sudo mount /dev/sdXY /home/mountpoint
