I installed Ubuntu on my Asus G750JS, but the WiFi in not working.
Some info :
$ sudo lshw -class network
*-network
description: Network controller
product: BCM4352 802.11ac Wireless Network Adapter
vendor: Broadcom Inc. and subsidiaries
physical id: 0
bus info: pci@0000:03:00.0
version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=bcma-pci-bridge latency=0
resources: irq:18 memory:eda00000-eda07fff memory:ed800000-ed9fffff
*-network
description: Ethernet interface
product: QCA8171 Gigabit Ethernet
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:04:00.0
logical name: enp4s0
version: 10
serial: 40:16:7e:11:a1:4b
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=alx latency=0 link=no multicast=yes port=twisted pair
resources: irq:19 memory:edb00000-edb3ffff ioport:d000(size=128)
*-network
physical id: 1
logical name: enp0s20u4
serial: 5e:7d:35:46:96:50
capabilities: ethernet physical
configuration: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.101 link=yes multicast=yes`
$ lspci -vnn | grep Network
03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4352 802.11ac Wireless Network Adapter [14e4:43b1] (rev 03)
Subsystem: AzureWave BCM4352 802.11ac Wireless Network Adapter [1a3b:2123]'
I tried:
$ sudo rfkill
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 unblocked unblocked
This doesn't make any difference:
sudo rfkill unblock all
I also tried:
sudo apt-get purge bcmwl-kernel-source
sudo apt update
sudo update-pciids
sudo apt install firmware-b43-installer
sudo reboot
sudo apt install bcmwl-kernel-source
This as well:
sudo apt-get install --reinstall git linux-headers-$(uname -r) build-essential dkms`
Nothings works. Does anyone ever had the same problem and found a solution? I spent hours on forums and tried different things, but nothing changes. The WiFi still doesn't work. I obviously tried the FN+F2 button combination.
