My Ubuntu 18.04 repo is broken with the "Depends: xxx but it is not going to be installed" error. Further investigation makes me believe it is caused by the conflict naming convention of the package versions:
% apt install libqt5gui5
 libqt5gui5 : Depends: libxkbcommon-x11-0 (>= 0.5.0) but it is not going to be installed
% apt install libxkbcommon-x11-0
 libxkbcommon-x11-0 : Depends: libxkbcommon0 (= 0.8.0-1) but 0.8.0-1ubuntu0.1 is to be installed
% apt-cache policy libxkbcommon0
libxkbcommon0:
  Installed: 0.8.0-1ubuntu0.1
  Candidate: 0.8.0-1ubuntu0.1
  Version table:
 *** 0.8.0-1ubuntu0.1 100
        100 /var/lib/dpkg/status
     0.8.0-1 500
        500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
I.e., the libxkbcommon0 was 0.8.0-1ubuntu0.1 when I first installed it, but it is now of version 0.8.0-1 (same version but without the ubuntu0.1), which is causing the trouble all the way up to the "Depends: xxx but it is not going to be installed" error.
How to fix it?
PS. my system:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04 LTS
Release:        18.04
Codename:       bionic
$ uname -rm
4.15.0-20-generic x86_64
I.e., I don't have other non-x86 architectures in my sources.
xpt
  • 1,197
