I'm able to install wine just fine, but get an error when I try to install wine-staging:
Reading package lists... Done
Building dependency tree
 winehq-staging : Depends: wine-staging (= 4.16~bionic)
Kulfy
  • 18,154
It is a problem in dependencies wine-staging needs
Depends: libfaudio0 but it is not installable
This package is not available in ubuntu. I run in the same error.
you can try the package from this source
sudo dpkg --simulate -i libfaudio0_19.07-0~bionic_amd64.deb
If no error accure remove --simulate from my command I'm not able to test because of my 32-bit system.
nobody
  • 5,792
