Each time I want to use my usb external hard drive for the first time there is a short latency for allowing it to run, how to make it run at all time, so that while for example I watch a movie, stop and goes back to it it run instantly.
It would be best to have a script that stop it from shutting down for a certain period of time
Saxtheowl
  • 2,394
  • 22
You could use hdparm to do this. Run sudo hdparm -S /dev/sdx | grep level to see what the current spin-down time of the drive is. Replace /dev/sdx with your hard drive.
You can change the spin-down time to 0 with sudo hdparm -S 0 /dev/sdx, changing /dev/sdx to the identifier for your hard drive.
I do not recommend disabling the spin-down time, as it will decrease the lifespan of the hard drive.
